Drilling large hole over small and vice-versa
  • Drilling large hole over small and vice-versa
    Good day
    I have a cheap DP and when I want to change the table height I have to unlock the table and while turning it left/right pull it up or push it down.
    I have no problems till I want to drill a large hole over small hole or vice-versa. In this case you must maintain the table at the same position but, if one drill is long and the other is short, you must re-adjust the table height and it is very difficult to return to the same position so the large hole will be drilled at the center of the small hole or, the small hole over the large hole center.
    So, that's what I did
    Regards
    niki
    Re: Drilling large hole over small and vice-versa
      Excellent pictorial. Thanks for sharing. Another useful insert for a DP table is a round, offset insert. When you blow out a spot on the insert, just rotate it to a clean, new spot. I find that I get a lot more mileage out of the round inserts.
        You should send your ideas to Wood Magazine. You'd make an excellent writer for them.
          at first i thought you were looking for advise
          then i read on
          i don't know if i was more impressed with your method or with your photo layout
          great post with details and photos.
            Thank you so much Gear Junkie and Rick
            I did...this idea was published in Wood Magazine and I got $75...
            For another idea (Cutting miters for picture frame), I got this
            http://www.amazon.com/Fein-MultiMast.../dp/B000U8S3QA
            Regards
            niki
