looking for router table attach to table saw
  • looking for router table attach to table saw
    hi,,all
    i have ridgid table saw and i want to add a router table to it,,please let me know what router table is work for it,,i think its 27"
    the only place i know is mulecab.com but they don't have it,,,anyone here know where or what table saw would work best ? but not too priceys? thanks
    Re: looking for router table attach to table saw
    It's pretty easy to fit nearly any router table that spans at least 27" to a TS. You can make your own in a matter of an hour or so, or buy one of the many 27" router tables with precut holes for router plates...MLCSWoodworking, Rockler, Freud, Grizzly, BenchDog, Woodpeckers, Woodcraft, Eagle America. Most won't be a direct fit, but are pretty easy to adapt.
    There are tons of examples...Google "router table" or "Router table plans".
      Scope out the general international router table attachements for the TS. Cast Iron, methinks about the 130$ range, Kill two birds with one stone...Ts table gets larger, no wimpy router table tops to sag and droop. (and unless they'r metal, they all do this. Added bonus, with a modicum of refinement, yer TS fence doubles as a router table fence.
      To me most economical choice. Scope it out, make yer own decision. Remember, cast I ron don't sag...
      Eric
      in Calgary
        Just a side-note. The BenchDog ProMax is a direct fit. Bolts right on to replace the wing. You can drill new holes if you want to bolt onto the side wing itself (will require additional leg support if you extend the table that far.)
          I like this one from grizzly.com
          Price: $199.95
          Freight: $44.00
          Package includes two support legs. Legs need to be modified to fit the Ridgid ts3650 - ts3660
            Originally posted by kvmn View Post
            hi,,all
            I just made 1 last night. Made from 1-1/2" oak faced plywood (2 pcs 3/4" glued together). Cut ends to fit in the front and rear guide bars. Made the insert out of 3/4" oak faced plywood. Made a fence that fits right over the existing saws fence. This thing is solid as a rock, wish I would have made 1 a long time ago. Made from scrap wood and it exteded my saws working area. Today I will finish sand, stain once dry I will coat with car wax.
            Good luck
              OT: Chazman, what lens are you using on your XTi?
                one that only takes bulry picts. Actually a 50mm lens takes great pictures but when I saw this one I was going to retake it but the table saw is in the pole barn and it was raining. LOL
                  nicely executed router table. especially satisfying when you know you made it out of what was lying around. just be careful about the final waxing. car wax contains silicone which can adhere to work pieces that slide over the surface. if the workpiece is to be stained or painted, the silicone can prevent a finish from adhering properly.
                    Aperture Value: 1.35614
                    Color Space: sRGB
                    Custom Rendered: Normal process
                    Date Time Digitized: 2009:10:30 07:54:44
                    Date Time Original: 2009:10:30 07:54:44
                    Exif Version: 2.2.1
                    Exposure Bias Value: 0
                    Exposure Mode: Auto exposure
                    Exposure Program: Action program
                    Exposure Time: 1 / 249
                    Flash: Flash did not fire, compulsory flash mode
                    FlashPix Version: 1.0
                    FNumber: 1.6
                    Focal Length: 50
                    Focal Plane Resolution Unit: inches
                    Focal Plane X Resolution: 4433.295
                    Focal Plane Y Resolution: 4453.608
                    ISO Speed Ratings: 400
                    Metering Mode: Pattern
                    Pixel X Dimension: 3888
                    Pixel Y Dimension: 2592
                    Scene Capture Type: Standard
                    Shutter Speed Value: 7.96579
                    White Balance: Auto white balance
                    Firmware: XTi
                    Flash Compensation: 0.25
                    Image Number: 7
                    Lens ID: 2
                    Lens Model: Canon EF 28mm f/2.8
                    Serial Number: 720350343
                    Make: Canon
                    Model: Canon EOS DIGITAL REBEL XTi
                    Orientation: 1 (Normal)
                    X Resolution: 72
                    Y Resolution: 72
                      To avoid this blurry effect, increase the depth of field by decreasing magnification. Zoom Wide and dolly (walk) the camera closer to the subject to frame the subject accordingly.
