Ridgid Oscilatting Sander. Happy with it
    Re: Ridgid Oscilatting Sander. Happy with it
    Got one this summer, works sweet with spindle but seems to be alot of vibration with belt
    Never outsmart your common sense
      Just to add...
      a clean sander is a happy sander!
      The dust collection port is fair.
      after you use the sander for a while stop lift the orange plate and blow out the fine dust/saw dust away. Even a Ridgid wet/dry vac may not suck it all up.
      Use compressed air.
      I also find using those rubber sander cleaners very useful as it gives the sanding drum
      a longer useful life.
      Finally do not force your work!!!! light pressure is all you need. make a pencil line and you can monitor material removal. Forcing the work will cause stress on the bearings, belt, and
      cause an early demise!
      I have used my sander now for close to two years without any incident by following those simple steps mentioned above
      Cactus Man
