I really like making Mission Style furniture. When given the opportunity I will always come down on the side of mortises and tenons for joinery. BUT! I am doing a project now that has stiles and rails that are over 2 inches square. Beautiful to work with, but one exception. There are many through tenons, and they are double through tenons. That is a whole lot of work that has to line up properly, and it is very difficult.
But the problem I am having is making the mortises that go all the way through a 2 inch piece, and I have a problem getting a real nice neat cut on the down side. Even though I have a piece backing up the cut, I get more tear out than I like. I could be more specific in identifying the front side knowing the shoulders cover part of that when glued, but I have to think I need to do a better job upstream in the project so there is less work compensating for a bad cut or a large tearout.
The project is working with cherry, 6/4 and glued for additional size. I have a Delta Mortise machine, but I don't seem to be very proficient with it. I have been into serious woodworking for under two years, and I still struggle with the required precision.
Any tips would be appreciated on cutting mortises. I have been told by some to ignore the plans when they call for through mortises. What do you advise?
