belt tensioning procedure r4511
  • belt tensioning procedure r4511
    Just purchased a R4511 Table saw. Anyone know where I can find the belt tensioning procedure? The manual does not address this.
    Re: belt tensioning procedure r4511
    Are you having problems? It is my understanding the weight of the motor should pull the belt to the correct tension. Of course, you should make sure the motor can rotate freely and there is no obstructions... of course, I could be entirely wrong...
      weight of the motor provides the tension on the R4511
        In addtion of the weight of th emotoer there aslo is a spring to keep tension on the belt. no adjustement neeeded.
        Make sure that the pulleys are aligned, mine wer 1/4" off.
        Bert
