Mortise and tenon methods(aides)
  • Mortise and tenon methods(aides)
    Does anyone have a simple way or aide in producing mortise and tenon joints using nothing but a hand held drill or table saw?
    www.TheWoodCellar.com
    You can cuy the tenons on a table saw with a dado blade or a regular blade if you have the patience.
    You can drill out for a mortise if you are good with a hand drill than square up with a chisel.
    SCWood
      See the easy-to-make tenon jig that I use on my table saw at www.plesums.com/wood/tips/tenonjig.html
      No easy answer for the mortises, but I compared the options at
      www.plesums.com/wood/tips/mortise.html
      Bottom line - I tried all the tricks without spending money, except for the bandaids for the blisters on my hands. Eventually I bought a drill press with mortise kit.
