R4511 Splitter Alignment
  • R4511 Splitter Alignment
    I was looking at the assmbly instructions (Yes... I know they are worthless). However, the manual references the (4) splitter adjustment screws??? Am I wrong... but to me it looks like the only adjustment on the splitter is the (2) bolts on the splitter arm. The (4) bolts the manual references do not appear to be adjustment screws, but rather part of the arm that holds the splitter.
    Any advise on aligning the splitter. I do not seem to be making enough adjustment as it wants to lean right.
    Re: R4511 Splitter Alignment
    Yes, the manual is wrong. The 2 - 5MM socket head cap screws are what you must loosen to align the riving knife to the blade.
      Thanks... that was my assessment as well. Adjusting it will test your patience.
