220v wiring for r4511
  • 220v wiring for r4511
    what amp breaker and size wire would i need to use to wire my 4511 for
    220?
    Re: 220v wiring for r4511
    There already is an exiting thread about these questions.
    http://www.ridgidforum.com/forum/sho...&highlight=220
    Bert
      Uhhh...is it me, or does the link bring you back to this exact same thread?
        Use the search tool and search for 220.
        Bert
          220?
          In most places it's 120/240 now. In any event you will use about half the amperage with 240 than you will with 120.
          #14 wire is 15 amp capacity.
          #12 " " 20 amp capacity.
          If the saw needs 12 amps then #14 wire will carry the load.
          12 x 120 = 1,440 Watts.
          1440 * 240 = 6.00 amps. so a #14 wire will easily carry the load.
          Example a 60 watt bulb uses .5 amps, 60 watts * 120volts = .5, so you could have 30 60 watt bulbs on a #14 wire circuit.
          Bear in mind you need a Two Pole breaker.
          Good luck
          Buck
