Watco finish
  • Watco finish
    I have made a jbox out of Black Walnut. To finish I did 3 coats of Watco (natural), wetsanding in the first 2 coats with a 320 grit and the last coat with a 400 grit. The finish is nice and beautifully rich. My question(s) are -
    1) Will this finish dry out and need recoating down the road ? How long might that be ?
    1a) Does Watco provide a hard finish under the surface of the wood ?
    2) If I give this box away, the new owner might just use Pledge on it. Will that ruin the finish ?
    3) Would several coats of a satin wipe-on poly negate the richness that the piece now has ?
    thanks all
    (all answers assume Watco Danish Oil product. They make other products...)
    "Dry out" is a misnomer, spread by companies selling products marketed as "feeding" the finish. A finish that looks "dried out" is one of two things: (1) worn off, (2) scratched. Wax or furniture polish will temporarily help number 2.
    No.
    No. It will make refinishing darned tough, but it won't harm what is there.
    I have found that different people have different values for the word "rich". It's impossible to say. It will certainly change the appearance somewhat. At the very least, I recommend using gloss for your "build" coats, and only enough satin to get the sheen you wish. Satin is less clear than gloss, is the reason. If you have a scrap piece left over, testing is absolutely the best idea.
    Dave
      Thanks, Dave. Yes, I did mean Watco Danish Oil. was hoping to be done with this soon, but I think I will try out a test piece first. I hate having a nice piece go from WOOHOO! to BOOHOO! because of impatience. thanks again
