durock
  • durock
    when putting up durock for a tub with tile do you tape the seams and (or) is mortar good to put in the seams
    Thank you
    There is a mesh tape made specifically for use with durock (and other mortar set backer boards) that you bed into mortar over the joints. Don't confuse it with the fiberglas mesh tape used for sheetrock.
    The tape and mortar serves the same purpose on backer board as it does when using sheetrock, by bonding the joint together.
      Thanks for the help
