R4511 blade alignment at 45 deg.
  • R4511 blade alignment at 45 deg.
    the main table top was cracked. HD replaced the top. While removing the top, all the shims fell off. How does one decide where to add shims to adjust table top when the blade is tilted for 45 degrees? Thanks.
    Re: R4511 blade alignment at 45 deg.
    Check out this post: http://www.ridgidforum.com/forum/sho...highlight=4511 It has a lot of info on blade and table alignment.
    Brian
    Brian
