R4511 extension table leveling
  • R4511 extension table leveling
    I have one place on the left extension table that wants to rock a little on me no matter how I adjust the other 3 setscrews on that wing. It's where the ext. table goes up against the main table. Since the extension tables slide in on the support bars I can't figure any way to shim it-but I can probably hold it down flush with the main table while I tighten the nut on the threaded stud adjacent to this area of the ext. table.
    Anything wrong with this plan, or does anyone have a different suggestion?
    Thanks,
    Ed
    Re: R4511 extension table leveling
    I had the same exact problem on the left side. Had to just keep playing with while I tightened the wing. Eventually, I got it where I wanted it with no problems.
      Well that's pretty much what I just did.
      Hopefully the 3 studs and nuts per side will hold it.
