Woodpecker router plate for a R2930
  • Woodpecker router plate for a R2930
    Does anyone know if there is a pre-drilled Woodpecker router plate that will fit the Ridgid R2930 router?
    Re: Woodpecker router plate for a R2930
    I'd have to go back and check my records (not at home at the moment), but if I recall correctly, the R2930 is compatible with the Porter-Cable 690. I use a Rockler plate, but at the time they didn't list the R2930 and on recommendation from others here on the forum, I ordered the plate that was compatible to the 690 and it was a perfect match.
    Only thing I had to do (if you want) was to drill an extra hole for the T-handle, in order to have above the table height adjustment.
    I'm be back home tomorrow evening and I'll check my records and re-post.
    I hope this helps,
    ps, Welcome to the forum!
      I was hopeful that something like that would be the case. Dilling an additional hole for the height adjustment is well within my pain tolerance. Thank you in advance for you help CWS.
        Jaydog,
        Ah, my memory didn't fail me... it was the Porter-Cable 690 which the Ridgid R2930 was compatible with. Here a copy of that portion of the packing slip.
        I hope this helps,
          CWS, you da man! Thanks again for the help. I will order it tonight.
