Fence Handle R4511
  • Fence Handle R4511
    Help, please. The fence handle on my newly assembled R4511 is so loose that gravity alone locks the fence. This is very inconvenient, because I have to hold the handle up while moving the fence. Is this typical or can I do something about it?
    Re: Fence Handle R4511
    I replaced the pin with a smooth bore bolt and nylon nut. But then, I did it to install a Wixey fence gauge.. Regardless, would allow you to tighten up on the sides and keep the handle from slumping.
    Just be sure that the bolt is SMOTH for at least 85% of the way through. Else you'll cause wear to the handle on the inside.
