R4511 Granite Top Fine Adjustment Aid
  • R4511 Granite Top Fine Adjustment Aid
    The pix show a very simple aid I added to my R4511 to make it easier make fine adjustments to the position of the granite top. It is simply a short piece of steel drilled to fit one of the bolts that hold the rear guide rail and extending just below the bottom edge of the granite. It is drilled and tapped to take a screw that presses against the top of the cabinet side. This moves the granite top by pressing against the top of the cabinet as the screw is turned in.
    It only works one way of course, so you back off the screw, push the top so the screw contacts the cabinet, and turn the screw to push the top until it comes into alignment.
    Re: R4511 Granite Top Fine Adjustment Aid
    Amazing how things can be sooooo simple if we just take a moment and think from another perspective! Nice work!
      awesome mod! Love how obvious and easy some things are.
