BS1400 Blade Guide Blocks
  • BS1400 Blade Guide Blocks
    Other than the cool blocks, does RIDGID have ball bearing blade guides or will most any guides on the market do cush as available at Grizzly.com?
    Although we do not make any ball bearing guides there are some aftermarket sets available. A popular ball bearing guide system called the Carter Guide will work on your RIDGID bandsaw. In most catalogs it is listed under only Jet and Delta. The Carter Guides for the jet will fit on the RIDGID bandsaw.
    The is another manufacturer (though I can't remeber the name) that makes a set of ballbearing guides that fit right in where the guide blocks are mounted. They're cheaper the Carter Guides, but have smaller bearings.
    Hope this helps
    Jake
      That is Iturra Designs that Jake is trying to remember. The product is called "Bandrollers".
      Iturra has no web site, number I find for them is (888) 722-7078. If you talk to a guy named "Louis", he's Iturra.
      Dave
