EB4424 Sander
  • EB4424 Sander
    Does the sander oscillate up and down in the belt sander configuration?
    If so, how high does the belt come up?
    It uses a 4" belt but there is only 3" showing on the floor model.
    I'm almost ready to buy it.
    Thanks for your help!
    Rob
    Yes it does oscillate in the belt sander configuration ... 3/4" specs below
    Specifications
    Motor: 3/8 HP, 4.6 Amps 120V AC
    Transmission: RPM 1725 Spindle, FPM 1350 Belt
    Oscillation: 60/Min.
    Stroke: 3/4"
    Sanding Sleeves Provided: 1/2", 3/4", 1", 1-1/2", 2"
    Sanding Drums Provided: 3/4", 1", 1-1/2", 2"
    Belt Size: 4" x 24"
      As a belt sander, it gets a 1 rating out of 5. As a spindle sander, it gets a 3 out of 5 rating. This is my personal opinion, on a machine I've owned and used extensivly for nearly 2 years. Mine is pre OWT and gray. Indexing the table to the shaft @ 90 degrees is near impossable. The plastic components that seat the belt with the miter slot is too flexible to be accurate and useful. At best, it's a hobbiests machine. Best used for freehand work, and not precission sanding. And spindle sanding is 99% freehand, thus the higher rating for that...only.
