I purchased my saw 20 days ago and overall am pleased with it. I have noticed that the cast iron top seems to have a slight crown in it. When I set the 90 on the blade with a tri square, and then check the other side of the blade, it is not square, and when i split the difference between the sides, I can slip a sheet of paper between the top of the tri square and the blade on both sides.
Is this normal? If it is, it seems like I will always need to check the angle depending on which side of the blade I am cutting on.
On a related note, how much warp is acceptable in the blade, mine came from the factory with 30/1000ths side to side play
Thanks
Thanks
