Wood Magazine Outfeed Table
  • Wood Magazine Outfeed Table
    Who out there has made the outfeed table from Wood magazine? Is there anything you would do different? What dimensions did you use? Thanks in advance.
    Re: Wood Magazine Outfeed Table
    You probably will get more responses if you are a little more specific. Is the outfeed table you're referring to one of these?
      This is the outfeed table and work bench. This is the one that the table will store under when you are not using it as an outfeed table.
      http://www.youtube.com/watch?v=KZyguUCdw4s
        I love this outfeed table and tried to find the plan for it on Wood's website but had no luck.....any help??
        thanks,
        Ben
        FOUND IT!! Thanks
        Ben
          I build the Tablesaw Workbench and have been using it for some time.
          I did change the dimensions to accommodate my Ridgid TS3650 saw.
          I don't think I would make any modifications to the plan.
          I don't like the fact that the fence and blade guard have to be removed for storage.
          Overall, I like the workbench and use it all the time. It turned out to be a great addition to my shop.
          To download the plans,which cost about $8.00 ,log on to Woodmagazine.com. click woodworking plans. workshop projects,Tablesaws.
          Hope this helps
            I used the Wood Magazine plan as a guide to building my outfeed table. I chose to use a torsion box top, and modified the wheel system slightly. It's rock solid and is a great addition to my shop.
              chucker...nice job on the outfeed table. would you post a few more pics on the caster set up. if you have the ability, a video would be great. thanks.
                It appears that Chuckers table is setup similar to "Norms" assembly table. You lift each end of the table and the casters fall into place. Lift the end and pull the rope to raise casters and set table into fixed position.
                  Thanks Guys,
                  I am 95 percent sure that this is what i am going to build. Using a 1 car garage as a shop having something that serves to purposes is a must.
                  I am planning on using recycled bowling lane as the top. I wouldn't think you could get much sturdier than 2 1/4 inch maple.
                    Another great bench top is a solid wood door. You could find a local door and window store and take a used one off their hand generally for free. I replaced my front door some years back and have been using the old door as a bench, and a dang solid one at that, for the lat 7 years or so.
