90 degree stop on TS3660
  • 90 degree stop on TS3660
    Is there a way to modify the 90 degree stop on my 3660? When I crank back to vertical from a bevel, the stop is not very positive. It feels mushy, not a solid "clunk" like I'd like. So how do I know I'm not overcranking or undercranking?
    Re: 90 degree stop on TS3660
    I never trust the factory indicator when setting the angle of my blade. What I use is the Wixey Angle Gauge. Setting the angle of a saw blade is only one use for the Wixey. You can use it to set the angle of the fence on a jointer, the table to bit angle on a drill press to name just two other uses.
