R4511 Pulley
  • R4511 Pulley
    Hello, this is my first post having purchased one on the last R4511 TS's where I live. With help from the numerous posting about assembly the machine is assembled and seems to be working just fine but I am concerned about the pulley and belt. I don't see how one is supposed to verify things are lined up as I can't even see the pulleys on either the motor or blade. These are both at the back of the cabinet. Should I try to crawl in or is there are easier way? Also, by feel not sight, I believe there is no actual "V" pulley. Is that correct?
    Thanks
    Re: R4511 Pulley
    Try the blade tilt mechanism at the 45 degree angle.
      Re: R4511 Pulley
      Simple is best!
      Thanks
