any thoughts
  • any thoughts
    on on aftermarket miter gauge for a rigid ts2424?
    Andy B.
    Re: any thoughts
    Depending on how fancy you want to get or how much money you want to spend, any one of these will serve you well;
    Incra 1000SE
    Incra V120
    Incra V27
      Re: any thoughts
      Been using the Incra 1000SE for about 3 yrs. A little pricey, but very
      precise. Really like the expansion discs on the side of the bar that
      eliminate any side play in the slot.
        Re: any thoughts
        I've been using an Icra 1000SE with my TS 2424 for about 5 years now. It is consistent, accurate and precise. I can easily set fractional angles with it. It is always accurate when I swing back to 90 degrees. The stop system works well. It is fairly easy to make adjustments. Pretty easy to add a backer board - seems like I had to run to the hardware store to get a few bolts and square nuts. It seems to be durable (but I haven't dropped it yet). I never use the rule to set cut length, so can't speak to that element. I've been pleased with it and recommend it.
          Re: any thoughts
          get either of the two lesser miter gauges linked by BD. they will do whatever you need to do. i have a 1000se and don't really like it that much. it's overly complicated and a lot of the adjustments aren't immediately intuiutive. save your money for other improvements to your saw. BTW, i use the 1000se on a 2412, very similar to your 2424.
            Re: any thoughts
            I've used an Osborne 3 for about 5 years and have nothing but good to say about it. I recommend that you go to a wood working store like Woodcraft where you can get your hands on several models and choose the one you like the best based on feel, simplicity and price.
            Blind Bill
              Re: any thoughts
              Blind Bill
              I agree 100%. Very good miter gauge for the money.
              Red
              Red
