Add t-slot to older ts2400?
  • Add t-slot to older ts2400?
    I have a two year old TS2400 (the mobile table saw).
    I just saw the new model, which appears to be essentially the same saw except for a t-slot miter attachment.
    I would really like to have this feature on my current saw. Anyone have any ideas what can be done with the aluminum top to add the t-slot?
    I figure there are two ways to do it - enlarge the current slot to hold a t-slot (screw in), or cut a T in the bottom of the current miter slot.
    Is attempting to modify the current aluminum top foolish/dangerous/suicidal?
    Thanks!
    Roger
    Roger, check around before doing any modifications. I believe it was Woodcraft that I saw the T slot track that will fit inside the miter slot of your saw. Or it might have been Rockler. I have been meaning to look it up and order some but have just been too busy. I also have the Gray model 2400 Just looked and found this http://www.rockler.com/ecom7/product...ctgroup_id=451
    [ 04-06-2004, 05:36 PM: Message edited by: papadan ]
      Thanks - the only problem is that I have an Incra 5000 sled that requires a normal sized slot. If I put a t-slot inside of my existing slot I won't be able to fit this miter guage in it.
      The Rockler site had an Amana t-slot cutter. I sent an email to the Amana technical support email address to see if they have anything they recommend for cutting this aluminum top.
      I guess I could always find a machine shop locally with the equipment to do it correctly.
      Thanks again!
      Roger
        Roger, I am planning on drilling and tapping the original slot and mounting the T with flat head screws so that it can be easily removed for my Tenon jig and crosscut sled.
          If you check the parts catalog for the TS24000 your saw and the TS24000LS new saw they use the same catalog. Perhaps you could just order a whole new top P/N 827546. If you call the parts line they should be able to tell you if it will work 1-866-539-1710. No idea of cost
          Ridgid WW parts catalog
            If you try to re-machine it you won't have anything the material in the top isn't thick enough. I think you find this out if you get down with a flashlight & look up at the bottom of your saw.
