Ridgid R4512 Table Saw: Unpacking and Assembly
This is a sticky topic.
  • Ridgiduser10
    I got one of those also. I successfully got it put together to find that I have a bent castor. I guess I can deal with that. My main issue, or rather biggest problem was getting rid of the giant box and all of the styrofoam. The week before I had purchased the 6 1/8 joiner/planer. Same problem getting rid of the enormous box. I finally took a box cutter to them and cut them up into many pieces and stuffed them into my trash can. It still took me a few weeks to get rid of it all.
  • Umpire.20
    aaron_s ....... I've never had that problem with the motor bogging down. I would ask 2 things though.
    1. are you possibly feeding the stock through too fast?
    2. Did you change the blade that came with the saw?
    A better blade (and one matched to the cuts) is a big deal also. It took me a while to understand that when ripping you should use a 40 or fewer teeth blade. For crosscutting you can step up to 60 or more teeth depending on the material you are cutting. The Forrest Woodworker-II 40 tooth blade does an excellent job of ripping and cross cutting on hardwoods. When I cut plywood (just did a project with 3/4 Oak ply) I use a 60 tooth blade and have VERY good results. My saw sits quite solid on a fairly flat garage floor. Occasionally it will wobble slightly and I just "wiggle" it a bit & it settles right down. Perhaps something got under the leg.
  • aaron_s
    Will do - I finally got the thing completed last night and got it going. Had a bit of trouble trying to pass a large sheet of 5/8" plywood through it for a 24" rip cut. Almost like the blade was starting to seize up and the motor was struggling. Turned it off, back on, and made some headway. Finally after cutting for a bit a chunk of wood about 1/2" thick and 20" long fell out of it and it started cutting a lot better. Guess I should check more frequently around the inside if there are chunks that could seize the motor. Anyway, that might not even be the problem because it kind of kept doing the same thing...
    As for the legs... I moved it around the garage a bit and set it down and solid as a rock. And then for some reason an hour later, I can't remember if I moved it again or if it had been in the same position, but it had a wobble in it (blade is/was off by the way). Not sure... scratching my head, slightly irritated.
  • Umpire.20
    @ aaron_s --- Be certain to check the blade for being square to the miter slot. That's a CRITICAL part of the set-up of this saw. Once that's good you are good to go. Make some sawdust!!!!!!!!!!!!!!!!!!
  • aaron_s
    I just bought this saw yesterday and got started on the assembly. So far so good but I've got to admit.. putting the darn thing together isn't a simple 1-2-3 task, and the instructions could definitely be a little more clear. I'm no dummy, and certainly am not a woodworking pro, but Ridgid sure could help by making the instructions a lot more clearly organized and to the point.
    Overall though, I am very impressed with the sturdiness of the construction... the stand currently wobbles a bit, I'll have to double check my work and ensure there's nothing holding it up because it'd be a shame for this thing to be perfect in every way but have uneven legs (and no, it's not an uneven surface). Can't wait to get that blade purring.. hopefully all will be complete tonight!
  • Umpire.20
    Originally posted by rick_stamp@hotmail.com View Post
    I just bought this saw as a somewhat assembled floor model. On getting it home, I noticed that the worm gear that raises and lowers the blade is not engaging the teeth on the main trunnion. It looks like the end of the worm gear rod should fit in a slot on the end of the trunnion, but it is out of alignment. Any ideas on fixing this? it's pretty tight quarters in there.
    I'd return it. Even as a floor model, they can't sell a non-working saw.
  • rick_stamp@hotmail.com
  • Umpire.20
    Re: Ridgid R4512 Table Saw: Unpacking and Assembly
    OK. I own the R4512 for a little over two years now. I must comment about the tables (wings) showing wear. The store folks don't align them as they should. If you align your table & extensions you'll have no problem. The bigger problem with the 4512 is the 2-piece front rail. Each time you pass over the junction, you will "jump" a bit. This jump didn't affect my cuts in the least. I have added a Vega Pro 40 fence & rail system to my saw. This allows a much wider/longer rip to the right of the blade. If I had it to do again, I would add a bissmeyer (sp) system rather than the Vega. Simply because it has better attachments to the front & rear of the saw.
    All this being said ......... I would absolutely buy the 4512 again and I would highly recommend it to others.
  • VLL
    Originally posted by CWSmith View Post
    Personally, I like the Ridgid titanium-coated blades. I'm using the 50-tooth combination on both my CMS and my radial arm saw, and in both cases the crosscut is quite smooth. Much of course, depends on the feed rate. In both cases, the blades have seen about two years service and are still performing great.
    On black Friday, Home Depot had this blade on sale for $30, normally they are $40. I picked one up and installed it on my Ryobi BT3100-1. Very smooth rips and I'm quite pleased. That saw spins at around 4800 rpm, and with the new 50T combination, it works very nice.
    On the subject of the 4512, I was in Home Depot a couple of days ago and got a much closer look at it. The new wheel/lift assembly appears to be better able to handle the saw, then did the conventional Herc-U-Lift on the granite-top 4511. Perhaps that is because the saw is a bit lighter, but still, I like the design of the lift better.
    I do like the fence, it's a three-point aluminum, very much like the one on my BT3100. On the latter, the fence is always locked down perfectly and over the years, I've never had a problem with it. The extruded T-slots in the fence make it ideal for jigs and sacrificial add-ons. And the 3-point T-square-like assembly securely locks fore and aft.
    I'm not so sure about the two-piece rail assembly though. Something about that joint/seam right there, almost in front of the blade, doesn't seem right to me. I would have loved to see a single piece rail, separately boxed/tubed; but, I do imagine handling during shipment and possible loss had some bearing on the final determination by manufacturing.
    The two stamped tables (wings), are sort of a negative I think and I really am not impressed with that support rod that goes between the front and real rails on the right hand side of the machine. That just strikes me as something to grab hold of, or hang something on and possibly leverage the rails into bending. I suppose the purpose is to keep the rails from being bent, but I would be concerned.
    The stamped-steel tables one could probably live with, only time will tell. But on the display unit, I could already see that there's a problem. On this particular 4512, the right-side table is too high and the fence hits it. too the point where you have to lift the fence at the front in order to get it to pass over the table. I suspect that the table is somehow adjustable, but it appeared to be solidly bolted to the rails and I didn't see any release of any kind. So, you probably have to loosen the bolts and hopefully the mountinig holes are slots, to allow for some "adjustment".
    But as it sat there, you could already see where movement of the fence was abrading the top front edge of this table and the paint was showing significant wear. Definitely NOT right!
    Other than that, I'd say the price is certainly right. But I do think I'd have to take a much closer look at the lift and tilt mechanism and of course the motor and drive. Keep posting those pictures.
    My little Ryobi BT-3100-1 isn't made with quite the same "oomph" that this beast has and so from that point of view there's nothing to compare. But with my other features, I think I need to wait awhile before I jump on a bigger saw. Still, it's always an ambition to see these new offerings from Ridgid and maybe hope that it might be a good reason to upgrade.
    Don't ever judge the quality of a tool setting on the floor of a big box store most of the time they are assembled by a person that couldn't find their butt with both hands, let alone read assembly instructions & follow them. Remember everybody learns differently & some can't read & follow instructions & don't care to. I've seen many many floor model tools improperly assembled in big box stores. Also mistreated with junk piled on them.
  • Ironman501
    I find table saws to be dangerous and less forgiving. However, cannot do without it especially with straight cuts. When the need is inevitable, remember safety.
  • Umpire.20
    Originally posted by seanster View Post
    I have this saw, only the older one. Purchased roughly 5 years ago it is a decent hard working saw. My issue is I have purchased some very thick solid oak 4X4's and its a challenge for the saw to chew through it. I've decided to convert to 220 volt and have the amperage dropped to save the motor. My buddy is a journeyman electrician but he's so busy I'm on my own. I kind of know what is required but a spec sheet would be best. Any help here? Thanks, Seanster.
    Sir,
    I can offer you the Sears manual for this same saw. I know it says Sears, but the saws are virtually identical. If you'd like to have it, send me a PM via this forum and include your e-mail address. I can then send it to you directly.
    I tried to attach it here but the forum says the file is too large. It is in PDF format.
    Umpire.20
  • seanster
    Originally posted by Brownie View Post
    As for the blades, I have a 30 tooth Freud Glue Line rip blade and a 40 Tooth Freud Premier Fusion combination Blade. I use the combo blade for plywood and crosscutting. The rip blade is dedicated just for ripping. They are $100 per blade, but well worth the money. If I had to choose just one, I'd go with the Glue Line rip blade. These blades are awesome and I highly recommend them. I am a weekend warrior too, but spending the extra money on good blades has been worth it to me.
    I have fought this for years....buying the high end blade for a superior cut line. I know it would save me time on sanding and joining, but I'm cheap. Guess I need to buck up, but $100. PER??? Yikes dude.
  • seanster
  • Brownie
  • GarageJunkie
    I got my saw last Friday. Assembly was easy, and they include the hex wrenches(I didnt realize this until the saw was built). Took about 2 hours. First cutting project was a mdf extension table for the right side and Im going to make a router plate to go there. Probably going to convert it to 220 also. I love the caster setup it moves easily and when I set the saw down its not moving. I wish you could line up the fence(left and right dialing in referencing the blade) with 2 set screws like on the delta fences. On this one you have to loosen 4 screws then adjust, not as easy to dial in.
