panel door trimming
  • panel door trimming
    Hi, can I run the edge of a small panel door through the jointer? Each edge of the door has about 2" of end grain.
    Thanks
    You can do this but you will need to put a scrap piece of wood behind the frame to prevent tear out of the end grain. Clamp it to the frame if you can. Good Luck!
      I've also seen articles/tips where people joint the first inch and then flip the door and finish jointing to prevent tearout.
      Michael
