workbench
  • workbench
    was searching for workbench plans, and ran across this ad,in my area on craigslist, what do you think as a bench top and price
    http://sfbay.craigslist.org/eby/mat/2103236959.html
    Re: workbench
    my best work bench is made from the pin setting area of a bowling alley, (I had to level mine but that is not that hard if needed,
    the lanes I think are made from hard fir lumber, the pin setting area (or mine was from maple)
    yes you will hard ever find that much weight and solidness for a bench than in bowling alley section,
    I banded mine with a oak edge,
    to flatten screw two flat boards on the long edges, level and make sure there parallel, extend past the ends of the top, up about 1/2" above the top average,
    then make a over sized router base from a piece of 3/4 ply that is twice as the top is wide, long plus about a 12" and about 8" wide, put in a flat bottom bit and find the lowest point and start to rout back and forth and sand out when done,
    this is a little different but the same idea for the way to flatten and level it,
    http://www.dans-hobbies.com/2008/06/...-sled/#more-50
    another on a smaller scale
    http://home.asparagine.net/ant/blog/?page_id=8
    here is a good article as well, most likely the first URL was taken form here,
    http://www.highlandwoodworking.com/f...tharouter.aspx
    over the years when there sanded and refinished, they can become crowned and dipped,
    but even if one would laminate a bench out of 2x4's or similar the method I stated above can be used to flatten out a top,
    I built a base out of angle iron for mine,
      Re: workbench
      Thanks
      Going to pick up the 6 footer this morning, thanks for the links
      Bill
        Re: workbench
        Be aware that thing is probably gonna have a million nails in it.
        Be careful with your cutting tools.
          Re: workbench
          was going to pick up bowling lane for workbench top, but checked craigslist this morning and ran across this add, I think this is better, no nails, maybe I can try to get it at a lower price, but the 400 maybe worth it http://sfbay.craigslist.org/eby/fud/2108026438.html
