R29302 Router Insert Plate
  • R29302 Router Insert Plate
    My wife purchased the R29302 router combo kit for me for christmas. This is my first router, so i'm a complete newbie. I'm looking to get a router table for it. I think I'd prefer to build one, since it would be a great learning experience for me.
    I'm somewhat limited in space, so I was thinking about making a "breakaway" one that mounts on the side of my work bench, and then breaks away or folds up when not in use. I haven't worked out the logistics on this yet.
    Whether I do this or not, I still want to build a router table. I was thinking about using 2 3/4" mdf sheets for the table top. I'm not sure what to do for the router plate insert, however. I'm assuming I should buy a metal insert, but i dont' know where to start.
    Can someone point me in a direction for getting a plate insert that is compatible with my router? If I'm way off base, can you point me in the right direction?
    Thanks.
    Re: R29302 Router Insert Plate
    Do you have a tablesaw? Have you considered replacing one of the wings or adding an extra wing as the router table? There are a few threads here with that solution.
      I do have an R4511.
      I wasn't sure of the cost involved to extend the arms and put a router insert into it. I'm fairly new to all things handy, so modifying a tool that already works seems a little scary.
        I use a Rockler table top and plate with my Ridgid router, but you can buy a plate from several sources and make your own table if you wish. Basically, any Porter-Cable 690-compatible plate should fit the R2930 router. http://www.rockler.com/product.cfm?page=21299
        I'm not a big fan of MDF. While it has great density, I think that normal 3/4-inch will sag from the weight of a router hanging on it. Perhaps double thickess or other means of reinforcement would be necessary.
        The Rockler table top is about an 1-1/8 inch thick and so far has held up well.
        A good router table top, if you can find one, is a sink "cut-out" from a kitchen countertop. At one time, you could get these from almost any kitchen installer, just for the asking. Not so sure how available they may be nowadays. They are a bit smaller than the Rockler table that I have, but certainly are larger than some of the tables that I have seen.
        I hope this helps,
          here is what a couple of 4511 owners did:
          http://www.ridgidforum.com/forum/sho...ht=4511&page=3
            I have that router and made my own insert plate out of 1/2 birch ply with some laminate on top. Using the ply means I can make multiple inserts for different routers. I have one for the Ridgid and for my PC690.
              Thanks for the info. Does anybody have good information for extending the arms to 6 feet or so?
                "arms"???????????
                  Sorry about that.
                  Extending the tabletop.
                  If I need new supports, both the square tube support and the "L" shaped piece, what am I looking for?
                  What dimensions, material, ect.. for the supports?
                  How thick of metal?
                  Are there predrilled supports available?
                    I saw space was limited for you, but if you can squeak-out a little more space I think you would be glad you did.
                    I constructed a table for one of my routers as a torsion box and covered it with a white, fine grain countertop material using contact cement. After that was complete I purchased a Lee Valley router plate that includes a template and good instructions for routing out the plate diameter (I would suggest purchasing the plate first so you can develop your proper clearances before you build the torsion box).
                    I built its stand after the box was done from 2X4s (you may want to do this first--it could provide a working surface). I created a lip around the box so it could be positioned onto, and removed easily from the stand.
                    After all this was completed I purchased "T" Track from either Lee Valley or Rockler and installed the three tracks (two for the fence and one for a miter head). The fence is made from MDF with a built in vac attachment. I have photos and drawings I can send if you’re interested.
