R4512 table saw
  • R4512 table saw
    Why is the R4512 not showing online on the Rigid website? Is it discontinued?
    Re: R4512 table saw
    Dan - I have no knowledge of the whereabouts of the R4512 on the website or of its availability at HD, but can tell you that if you can't find one, and you've decide that's the saw for you, the Craftsman 21833 is essentially the same saw from the same manufacturer AFAIK. It's on sale for $500 now.
      Re: R4512 table saw
      FWIW, all 6 surrounding HDs near me have 4512s either in overheads or in the tool area. they all show a price of $499. i'd push for the 4512 over the cousin craftsman, if only for the lifetime service agreement the 4512 can be covered by with proper registration with ridgid.
        Re: R4512 table saw
        R4512 returns as a result on the HD website from here.
          Re: R4512 table saw
          I just bought one today. $499 at home depot.
            Re: R4512 table saw
            It was only introduced a couple of months ago, so I doubt that it's gone away already. Probably just a glitch on the website.
            My two local Home Depots have just set theirs up a few weeks ago.
              Re: R4512 table saw
              Please help me to know!
              Anyone know about SPECIFICATIONS of motor this TS? Does it work with 220V or Only 120V?
              Thank you!
              Alex.
                Re: R4512 table saw
                http://www.homedepot.com/Tools-Hardw...atalogId=10053
                I don't see reference to converting to 220, but why would you want to?
                  Re: R4512 table saw
                  Thank you for answer! It'll be use in country with 220V. May be anyone (owners) can you say about this spec. from owner's manual?
                  Alex.
                    Re: R4512 table saw
                    Yes it is a dual voltage motor, 13/6.7 Amp. The Craftsman #21833 is listed as a 15/7.5 Amp motor.
                      Re: R4512 table saw
                      Thank you! To ptsbob - Do you have this TS?
                        Re: R4512 table saw
                        Reason for converting to 220 would be for better amperage demand. As you double the voltage, you half the amperage. So, if you're drawing 13 amps or so and are on a 15 amp/14 gauge line you're fairly close to pulling the maximum. So, if you could have an electrician move that particular circuit over to 220 and dedicate it to the saw, you'd only be drawing around six or seven amps through the same wire.
                        I hope this helps,
                          Re: R4512 table saw
                          YES!!!! The manual has all the instructions and diagrams to change it to 220 volts.
                          Thank you!
                          Alex.
                            Re: R4512 table saw
                            I was informed by my local Home Depot tool guy that the dado insert for the 4512 is 080035003093 part number and he ordered several for a list of waiting customers through Granger supply, Ridgid's parts distributor. He said it would take 3 weeks or so.
                              Re: R4512 table saw
                              web page in your link shows the parts are backordered until the end of July.
