Drilling through extension wing
  • Drilling through extension wing
    I just got a router table extension for my table saw. It's a xm extension from MLCS. My question is can I drill holes in my cast-iron wing? Can you drill in cast-iron? Thanks for your help!
    Re: Drilling through extension wing
    I am not familiar with the extension you purchased and how it mounts, but yes, you can drill cast iron.
    Use oil on your drill bit, slower RPM than for wood and keep firm pressure on the bit to keep it cutting (most folks don't realize that it is lack of forcing the bit to cut that burns/dulls your bit...keeping metal flowing across the cutting edge actually protects the cutting edges)
      Thanks tomapple, It will mount on the rails. I thought if I could fasten it to the wing, I would get a little more support.Cast Iron Router Table Extension and Fence
        If the extension table has the facility to bolt to the end of the saw table, I would drill some holes if it was me.
          Just finished the router table today, I did drill holes into the extension wing. Everything worked out great. Thanks tomapple for your reply.
            so where are the pics of the completed router table? i've thought about a mod like that and would like to see how yours was accomplished.
              OK I'll take some pics of the table. I haven't posted pics before, but I'll try.
