Door closing on its own
  • Door closing on its own
    I have an office with a wooden door and its keeps closing on its own?the other office doors don't close like this one does.
    There is no door closer and its a commercial wooden door.Any idea why it would be doing this? and what would be the solution to fix this?
    Thx in advance!
    Re: Door closing on its own
    The door jamb is a little out of plumb. (gravity does wonders) Cure--pull one of the hinge pins and put a slight bend in it. The friction will keep the door from swinging on it's own.
      I would check the wall for plumb and or the jam,
      Is there an air vent blowing on it?
      one more thing are the hinges worn, some hings can wear with a taper that would possibly case a self closing situation.
      and if there level/plumb and no drafts, and no defects, call the ghost busters.
        Thx in advance!
        ghost hunters!
          I also had a door with the same symptoms as the OP's. This morning I did what PK suggested and it worked like a charm, no more self opening door. Boy, them old guys sure know stuff don't they?
            Yep...well, except where they left their keys or to zip up their fly ROFL
              That's one good thing about winter. When you feel that cold draft where there shouldn't be one, you know you forgot to zip up.
                Yea went there today and didn't notice air ducts close by and she tells me that it only happens in the winter months and its a steel door not a wooden one.
                Couldn't try the bending hindge method but will try it tomorrow when I can get into to the office.
                Thx
                  It is most likely sagging the Jamb maybe try longer screws that will bite the jack stud through the hinge.
                    If the jamb isn't too far out of plumb, you can slip some business card shims behind to bring the hinge line back closer to plumb.
                    If that doesn't work, you can chisel the mortise for one of them deeper. Easier than it sounds, only takes a few minutes.
                      I agree with Andy M.
                      Another easy check is to close the door and examine the spacing around all four sides [top,bottom, left ,right] you should normally observe equal spacing. If the spacing is off you now know the door is not plumb and you need to address it.
                      The credit card spacer trick behind one hinge is also a reasonably quick and reliable fix.
                      Tom Silva from ask this old house did a segment on this exact challenge.
                      You may want to search the TV show's website for the segment and watch it.
                      Cactus Man
                        Worked like a charm Guys!
                        Thx again much appreciated!
                          anyone try these yet?
                          http://www.thequickdoorhanger.com/
