4424 spindle sander
  • 4424 spindle sander
    Have just purchased sander and in setup with edge belt the bottom 1/2" of the belt is rubbing on the "plate Wear" and removing a fair amount of material from it. I thought I had the belt positioned too low but that was not the case. What would be the normal wear expected from this part ??
    The belt will rub on the wear plate under most normal circumstances, especially on the lower section of the plate, since that is where you do most of your sanding. I wouldn't be too worried about it unless the belt is literally rubbing through the steel, which is very unlikely.
    Jake
      Thanks for the repl Jake but the "Plate wear" is on the "back" side item # 12 from parts list and it is made out of plastic or composite material??? (it is used to align the belt to the miter slot)
