saw dust collecting accessory for table saw
  • saw dust collecting accessory for table saw
    Saw dust collector accessory for model TS36500 table saw. I have totally enclosed the entire bottom part of my table saw, attached via a hose to the dust collector. Problem: where the motor is attached there is a considerable opening that is difficulte to cover. Does anyone know of any saw dust colloec ting attachment that would work with this otherwise great table saw. Thanks for any info/suggestion.
    Dear Guys - thanks to everyone for the replys. Please note, I discovered by reading the label on my saw that it is a Model 3612 NOT 36500 - tha Owner's Manual said it was a 36500. Model 3612 has no DP whatsoever - following the posted suggestions my shop now is pretty much free of table saw generated hickory saw dust.
    Regards to all, Bela
    [ 03-12-2005, 08:16 AM: Message edited by: bhorvath ]
    What I did was I took a couple pieces of ¼" hardboard and cut them out so that they would fit around the motor mount, blade guard mount and the belt. To secure the pieces to the saw, I epoxied some magnetic tape to the backsides. The magnetic tape makes for easy removal whenever I need to get at the inside of the saws cabinet.
    ------- Henry Ford
      I did pretty much the same thing but drilled holes with a forstner bit and epoxyed rare earth magnets----and used some thin foam tape around the edges.
      I can tell you it's just OK---not great. Also depends on your electrical set up----if you can use the DC and saw on dedicated lines, great, but if they're on the same circuit, when you bog the saw at all, you'll trip your breaker.
      Dave
        Did you guys remove the dinky dust collectio port and shroud from the underside of the saw and then cover the whole area with a DC port to the side?
        TIA
        Chiz
        Later,
        Chiz
          I have a 3612 and not the 3650 and my saw didn't come with any kind of a dust shroud. What I did was enclose the bottom of the saw with some ¾" MDF after I had cut a hole in it that would accept a toilet flange. I then hooked up a 4" flex tube to the closet flange and ran it to my DC. By closing in both the bottom and the back, the dust collection was improved to the point that I would consider it excellent, for a contractor style saw that is.
          ------- Henry Ford
            Hey Dave, I don't mean be a PITA but can I ask you this? Why 3/4" stock (I was planning on using 1/4")? Just what you had on hand or do you feel that you need it to stabilize the flange? Where did you place the flange - back, side or bottom?
            TIA,
            Chiz
            Later,
            Chiz
              "Why 3/4" stock (I was planning on using 1/4")? Just what you had on hand or do you feel that you need it to stabilize the flange?"
              I used the ¾" primarily because I wanted it to be as rigid as possible so as not to let any sawdust escape. Also, like you said, to give the flange something very solid to mount to.
              "Where did you place the flange - back, side or bottom?"
              Smack dab in the middle.
              ------- Henry Ford
                Don't know much, but I would say go for it. I like anything in my shop that will help me keep it clean.
                <a href=\"http://www.freewebs.com/buctooth\" target=\"_blank\">www.freewebs.com/buctooth</a><br />Please tell us how you like the site, even if you hate it. If you want, feel free to visit the forum.
