bs1400 question
  • bs1400 question
    Just bought a used Ridgid bs1400 (gloat on) (older grey model, 6 mos. old - $200)(gloat off) My question is this: there is no pin in the split in the table...is this something extra special or is there something I may be able to use with having to order one from Ridgid??
    Thanks in advance,
    Jim
    I have the same bandsaw, and could not be more satisfied. I measured the diameter if the pin in mine, and it read 21/64 on the dial calipers. I would order a new one from Ridgid. the part number is found in the manual. The manual can be downloaded from the Ridgid site. In a pinch a 5/16 piece of dowel rod with some asking tape might work fairly well.
    Good Luck,
    Mike Narges
