My take on the ZCI
  • My take on the ZCI
    After reading many questions and answers about zero clearance inserts,I decided to take pictures
    and post them,to show how I made My ZCI.
    After decommissioning a rather large robot at work,We kept an assortment of aluminum plate for home projects.
    After making several of various materials,I decided to make a reuseable insert with replaceable
    inserts.Here it is in the TS
    The Pic names explain the views
    Re: My take on the ZCI
    Very cool!
      Very well done. My only question is, how long does it take you to mill the blanks, compared to how long it would take to make an entire ZCI from wood? That's the one thing that always gets me, people come up with some really great looking, high-tech solutions to problems that are now more expensive, more time-consuming and really don't get you anything better than the old, tried-and-true wooden insert. What do you gain from doing it your way, as opposed to the other way?
        The satisfaction of doing it when everyone else thinks its not worth the trouble would be my guess. If you've got the skills and the tools why not? The AL plate with replaceable inserts does take less storage space.
        Nice job on making the custom ZCIs.
        For everyone else (including me), the all wood versions will do just as well I guess. If I had the toys (I mean tools) I would like to know how to machine one from aluminum.
          Glad You asked.The blanks shown below were made from 1 1/2"X1/4" aspen store bought at the HD on clearence.
          Ripped to 1 3/8" wide,edges rabbeted 3/16" wide X1/4"
          deep.Took about 10 Min.Now if I planed down a 2X12 to 1 3/8" and use the narrow ripping fence I made (shown below)made of UHMW polypropylene,I could make a few hundred a day.Also shown below is My push-stick,same material 1/2" thick with a sawsall blade for griping.I am going to upgrade that to a 2 blade design soon.
          Thank You Gentlemen,for Your kind comments.Jim
            I'm not saying he shouldn't, I think he did a fantastic job on the ZCI, it's something he rightfully ought to be proud of. I guess I'm just a substance-over-style guy, I want the best bang for my proverbial buck, why do extra work on something that doesn't give you extra benefit?
            I guess that's just me.
              I can see the benfit of having a lot of these little wood ZCI's made up and ready to use. Slide a new one in for whatever blade you have and away you go. If you had all full wood ZCI's, you would have to set them up to be level once made so you could use them whenever. With his idea, the leveling process is really only done one time for the aluminum.
              It could save time that way.
                Excellent job.
                Is that a box of kimwipes in the background of the one pic?
                  Very nice Jamesamd, I wanted to make one like that out of brass but my inserts are only 5/16 thick. I ended up using scrap laminate flooring for mine.
                    That would work fine,Dan.A 1/16" of brass for the lower support,will be more than enough,to support the slat.
                    Go for it man
                      Originally posted by tomapple View Post
                      Excellent job.
                      sure looks like it don't it?
                        That sure is some nice work James.
                          Yep. Them guys workin for AMD make so much money they can afford to use Kimwipes in the shop.
                            Excellent job.
                            iam sorry,it took solong to answer that,Tom.
                            The box is made by Tronx,non surgical examination gloves.
                            I use them,whenever I apply Dyes,stains or finish.
                            Educate Me Guys,what are Kimwipes?
                            And thank You all,for the encouragement
                            Jim
                              Jim
                              Ahh. My mistake. Kimwipes are a product from Kimberly Clark. They are a low-lint, non-abrasive tissue type wipe. Used in a lot of labs and quite frequently by electronic assembly houses.
