TS2412 Fence Problems?
  • TS2412 Fence Problems?
    Has anyone else had inaccuracy problems with the rip fence on the 2412? Mine is never square with the blade and I have to take a ruler and measure from fence to miter guide grooves or table edge to ensure a good cut. There does not seem to be a good way to adjust the fence. Also, has anyone upgraded the fence to a better grade or modified existing fence in any way? The fence is usually off about 1/8 from front to back of fence which is a huge problem as you know.
    The fence is easily adjusted to be parallel with the blade. On mine I did the following....I put a ruler from my combination square next to the blade (after adjusting it to the left hand miter guage), then moved the fence next to it. I loosened the four adjustment nuts on the fence and made it parallel to the blade, then locked the fence down. After tightening the nuts back down it should be fine.
    Kelly C. Hanna<br /><a href=\"\" target=\"_blank\">Hanna Woodworks</a>
