How To Post Images
See more
See less
Teak or Mahogany?
  • Teak or Mahogany?
    What's best for outdoor furniture, Teak or Mahogany?
    Something else better?
    Thanks for all ideas.
    Re: Teak or Mahogany?
    teak, but you still need to oil it. don't varnish it or you'll always have to stay on top of the varnish.
    what's better. pvc
      Redwood. In the south, it's Cyprus.
        ipe. sometimes called brazilian mahogany. wears like iron. so dense it doesn't float. a little pricey and it doesn't accept stains terribly well. in terms of synthetics, rick is on the money.
          I used cedar to make this glider from plans in the July issue of Wood magazine.
          Got about $200 in lumber, hardware, including the glider brackets, stain.
          You're only limited by how much money you want to spend.
          I like cedar 'cause it's available locally, not to costly, easy to work with,
          takes stain well, holds up in this harsh climate.
            Thanks all. Nice bench glider Jim.
            Where do ya'll get your specialty woods?
            Thanks again.
              Jim You do Awesome work ! Like the deck, and miters on step.
              This is is My 48th year as a carpenter, and cabinetmaker.
                I like both and Redwood. I have Two big -36" diameter redwood trees cut up to 12'
                lengths,at My Const. Yard.Waiting for New friend to return from Montana to Mill with His Lucas Portable saw Mill.Then air dry . Mom's gonna get some killer red wood furniture. Son Brian will Have fun also! He has surpassed Me on Cabinet and furniture
                Making.
                  I like teak for outdoor furniture. It will last the longest, and to my eye looks the best. I've heard good things about ipe, but haven't used it. Unfortunately teak, at least here, costs a fortune. Rick is right on... oil often, but stay away from any clear coat like varnish, marine varnish, polyurethane etc. You will be a slave to it, and besides, oil looks best.
                    I like mahogany out of your two choices. Cypress is very good and very affordable. White oak is also an excellent choice for outdoor use. You can oil it or let if weather and it won't blow over in the wind!
                    Red
                    Red
                      You can order online, but I prefer to find a lumber yard that deals in hardwoods.
                      Even if you have to drive a little, it's worth it to be able to pick put exactly what you need,
                      plus the prices are usually better.
