? For Big Johnson
  • ? For Big Johnson
    What did you use to secure the enclosure on the back opening of you saw? From the pictures I can't see any screw heads. I need to close mine up, I'm getting a lot of dust on the motor, and it makes me nervous.
    Andrew H,
    I used Velcro to attach the covers... I have it in sections to easily remove and replace as needed... I must take it off if I make a bevel cut thou, that is the only downfall… I hope to revise it one day to be permanently on the saw all the time… 90+ percent of my cuts are at 90 degrees… It works very, very, well with my new dust collector… [img]smile.gif[/img]
    Here are some pictures:
    Regards,<br /><br />Big Johnson<br /><br />Pictures: <a href=\"http://www.woodworkersweb.com/modules.php?set_albumName=albuv85&op=modload&name= gallery&file=index&include=view_album.php\" target=\"_blank\">http://www.woodworkersweb.com/modules.php?set_albumName=albuv85&op=modload&name= gallery&file=index&include=view_album.php</a>
      By the way, the picture doesn't show it but the large sheet has Velcro on it too... I can send you a better picture later this evening...
        Thank BJ, that looks pretty straight forward, and I have some pieces of scrap just the right size.
