cambering a plane blade
  • cambering a plane blade
    Anyone want to weigh in on this? I want to camber a new plane blade and have read many articles on this. I use the veritas MK2 guide, but don't feel i need to buy the "cambering" additional wheel.
    Anyone have some good tips on how to accomplish this?
    Re: cambering a plane blade
    Bob Smalser [sp] had put up a nice series of threads a few years back on here about restoring planes and chisels and sharpening them too.
    He did some articles for one of the WWing mags too, do a Google search might turn up some of his stuff on the 'net, I know I have come across it in the past other than here. I think I got his name spelled right, can someone else confirm or correct me?
      never used that guide, I do not know,
        It depends on how much camber you want. Using the Mk II, I usually just make a few extra passes on each grit pressing down with my fore finger on the left corner of the blade and then use the third finger for same process on the right corner. A final side to side swivel smooths out the radius. This gives a few thousandths camber which may not be enough for you if you are making deep cuts. The only seriously cambered iron I use is on my scrub plane, which I do free hand.
        Go
          I decided to buy the cambering wheel for the MKII. I must say it is well worth the 20 dollars - it does a superb job!
            Thanks for the follow up. It would be nice if more people let everyone know how something did or didn't turn out.
              You are correct Bob. Here is a link to many of Mr. Smalser's articles as well as many other tips. Look under Woodworking How Tos then Fossil Fuel Friendly
              Franklin, I use the same method as Gofor to camber my blades but I do it on my diamond plate so I don't put stripes in my water stones. I usually just knock the corners off on a small radius (~2mm) so I only have to redo them after many hours of use/sharpening
