free hand table saw use
  • free hand table saw use
    I was watching "Holmes on Homes" the other day (very popular renovation show in Canada) and there was a guy cutting hardwood flooring planks freehand on the table saw.
    This flooring guy was a seasoned professional. I could only shake my head -he is asking for trouble and should know better.
    Re: free hand table saw use
    I cross-cut freehand when the need arises, have been for years with no issues. Knowing what you are doing and paying attention is all it takes to do it safely.
      Me too. I know what I am doing.
      Someone once said: "It could never happen to me".......
      And then it did.
      I hear they put flowers on his grave every once in a while.
        I free hand cut on a table saw a lot. Works awesome for coping trim pieces to unlevel flooring or walls close to door ways.
            That's what the Massachusetts court suite was all about. When the Product Safety Committee decides in favor of Saw Stop, don't complain when saw prices double.
              "Spin the cylinder and pull the trigger".... CLICK! Must be safe!
              Yeah, I've seen a lot of guys do things that aren't safe, and their justification is "I know what I'm doing" and "I've never had an accident".
              Bottom line is that using a table saw "freehand" isn't safe and so far you've been lucky. While this may work (so far anyway) for you, my concern would be that someone else isn't using you as an example or learning from you.
                I disagree. I do it all the time and have been professionally for years. No worries. A guy just has to pay attention and not cut anything that is to big to be safe.
                  I have no use for Saw-Stop. Don't need it, don't want it.
                    i saw that same episode, franklin pug. freehand tablesaw use is a really bad idea.
                      A bit off topic, but... "Holmes on Homes" is a great show, watch it all the time here in the States. Mike is also on a new show, something like "All American Handyman" where they have to build stuff and a couple people get eliminated each show. I've only seen 2 episodes, but I have a big problem with one aspect of the show. They have to build something in a specified period of time, say an hour or 2. That means that they are encouraged to HURRY WITH POWER TOOLS...!! That is something that I refuse to do; I don't hurry in the shop, I don't hurry when I drive and I don't hurry when operating my sailboat. I'd be off the show in the first 15 minutes. But that's OK with me, I like my fingers. Hurrying is when you get careless and make mistakes.
                      Oh, and I wouldn't cut on the tablesaw freehand either.
                        I have done things with a chop saw that make me wonder wth I was thinking. I have free cut with a [edit] table[/edit] saw as well, slight curves to boot. Now I keep a jigsaw and coping saw with me at all times to avoid having to do that.
                          I'm confused on what you mean by free hand.....every table saw I've ever seen you have to push the wood.
                          If its close and I don't have a push stick handy I'll pull it the rest of the way.
                            Good point Vince. I'll bet some of us (including me) are assuming that by "freehand" he means he is not using a fence or miter gage to guide the wood through the cut and is just holding on to the wood and pushing it through the blade with only his hands.
                            But, his definition of "freehand" might be not using a pushstick or similar tool to maintain clearance between his hands and the blade.
                            If its the latter case; for me I would say yes, there are many times when you can use only your hands to guide the wood through the cut. IF its the first case; ie NO fence or miter gage or other device holding or guiding the wood, and the operator is depending on themselves to guide the piece straight through the cut, I think that is dangerous and no amount of experience can protect you from that piece of wood with the pent up stresses in it that cause binding during a cut and can cause kickback. Didn't we have a thread here recently which demonstrated how dangerous kickback can be??
                            What does a 3"x3" piece of kickbacked Pecan do to someone?
                              I personally think cross cutting free hand is a definitely NO no, riping with out a line light is a no no as well, but with a line light is reasonable safe, and the reason is one can hold the board in line, with the blade with out the line light it is very difficult and binding is most likely going to happen, on the cross cutting one can pinch a blade very easly,
                              but in general free handing (no use of fence or miter gage) in my opinion is a defiantly a NO No, but like I said I think one can rip fairly safely with the use of a line light, and chalk line as it works much like a fence for the operator, (it is just very difficult to keep a long or even short board in line with the blade with out some help),
                              but the best way to edge a board would be a power feed or a dedicated edger, which most do no have,
