table saw outfeed table
  • table saw outfeed table
    DOES ANYONE HAVE ANY PLANS OR IDEAS FOR ADDING AN OUTFEED TABLE TO A TS2412 EQUIPED WITH AN AC1036(THE 3'RIP FENCE)? I'M NOT A BIG FAN OF DRILLING HOLES IN PERFECTLY GOOD EQUIPMENT SO I AM PRIMARILY INTERESTED IN SOMETHING THAT COULD BE HUNG FROM EXISTING HOLES OR BOLTS. I'D ALSO LIKE TO MAKE IT REMOVABLES SO IT CAN BE LAID FLAT ON THE TABLE SAW TOP TO PROTECT IT AND DOUBLE AS A VERY LIGHT DUTY ASSEMBLY TABLE.
    IF YOU\'RE WORKING HARD, YOU\'RE DOING IT WRONG
    this may or may not be what you are looking for. I made an assembly table that stores some of my tools on one side, and my compressor on the other. I have it sitting on 5" casters. The final height is the same height as my table saw. When I need to use it as an out feed table, I simply roll it over to the saw. By the time assembly is started, I no longer need to use it as an out feed table. Kills three birds with one stone.
    Jim
