Picket fence help
  • Picket fence help
    Im building a picket fence does any one know what the max distance between pickets can be by code
    thanks charlie
    Re: Picket fence help
    thanks charlie
    Charlie, didn't know there was a code for this? Unless you were trying to keep critters in or out, what would the height or spacing matter? Post and rail is wide open, so why should picket be any different. I would keep spacing to the width of a picket just for looks. Frank
      Many cities have codes on fencing--and they are probably all different. You would have to check with your local building department.
        thanks i using 2x4x4ft so im going to space them 3 1/2" it looks ok
          charlie, i think that spacing would only come into play if there was a drop off on the other side. height is usually not to exceed 6' for yard boundaries.
          are you going to nail it or screw it
            height and spacing might be a factor is you are enclosing a yard with a pool in it.
            Light is faster than sound. That's why some people seem really bright until you hear them speak.
            “If I had my life to live over again, I'd be a plumber.” - Albert Einstein
            "Its a table saw.... Do you know where your fingers are?"
            sigpic http://www.helmetstohardhats.com/
              it is just in the back of the yard to keep dogs in and im using screws
                For handrails, a 4" sphere cannot pass anyplace thru it.
                  Check your local building codes. I used to issue building permits for a living, and I can assure you that it will not only become a matter of code compliance law, but also liability if some child or animal gets harmed as a result of non compliance. Cover thy butt twice on this one!
