re-ts2412 blade alignment
  • re-ts2412 blade alignment
    Gents,
    Thanks for the quick reply!! Unfortunatley I've been doing "honey-do"s and haven't gotten a chance to try aligning my TS2412 to the miter slot again until tonight.
    I raised the blade just short of the maximum height and reset it so the front and back were parallel with the miter guides. Everything looked great, until I lowered the blade to make a cut. I then checked the alignment again and found the rear was about 0.020" healed towards the right side of the table. Apparently there is something in the blade raising mechanism that causes the alignment to change with the height of the blade. Is there any adjustment under the table for this???
    SAHarness
