Spindle/belt sander problem
  • Spindle/belt sander problem
    I'm having trouble with the table on a 1 year old machine. The table is wearing noticeably and when I use the sander, the bottom of the item is marked by the finish coming off the table. I was told that the warrantee does not cover wear, but should it wear to the point where it makes more work by having to clean up the item? Just wondering if anyone else is having the same problem.
    Re: Spindle/belt sander problem
    Yup, some of the finish on mine has worn as well. I rub it from time to time with wax paper and it is not a problem.
