gear grease
  • gear grease
    I don't have my manuel here so I thought you experts may already know. I want to re-lube my TS riser and tild gears but I am not sure what grease to use. I think it is the white lithium grease but don't know if there are different types. Am I correct?
    Are you Rapture ready? Know Jesus Christ or know his enemy!
    The owners manual for my 3612 says to use SAE20 or SAE30 motor oil to lubricate the tilt and elevation screw threads. Personally, I've gotten very good results using a non-silicone spray teflon dry lube. For me anyway, it seems to take longer for sawdust to start building up using the teflon dry lube.
      Thanks.
      I believe I even have some in the shop.
