Fence alignment
  • Fence alignment
    I just checked both my TS's and both fences were a hair outta whack with the right hand miter slot. For those who don't think of it very often, it's a good thing to keep tabs on those fences. They can be knocked out of alignment very easily....
    [ 11-10-2002, 10:35 PM: Message edited by: KellyC ]
    I took mine apart by the handle and put a piece of wet or dry sandpaper(220?) between the gray pieces that you can adjust(with 4 bolts),and when I cut heavy lumber,I clamp a nice big chunk of wood to the table,tight to the back end of the fence to keep it from moving out to the right. Works pretty good so far! Try it. If you come up with somethin' better let us know!
      Excellent idea! I never thought of that one....very well done. The sandpapaer is a good idea as well, but the clamp would work very well for 3/4" plywood ripping. Thanks!!
