Crown Molding
  • Crown Molding
    I have a 12" Ridgid compound mitre saw and it has the legend that tells you how to cut crown molding for a 90 degree corner (sweet feature) so far it has kept me sane.
    However I have some 45 & 135 degree angles and I was wondering if anyone has a cheat sheet on what settings work with my saw?
    ___________
    Example is _________/
    Appreciate any thoughts!
    Onequik1
    First of all, welcome to the forum. [img]smile.gif[/img] This link might help. Then again it might not. I just don't know. I hate crown molding myself.
    www.dewalt.com/us/articles/article.asp?ID=2
    Lorax
      You are the man! I am cutting the crown using the flat method so for a 45 degree cut it is not as simple as 22.5 degrees!
      If anyone else needs to know this link is THE CHEAT SHEET! At the bottom it lists all angles.
      I obviously came to the right place, thanks Lorax! [img]smile.gif[/img]
        You're very welcome. Glad I was able to help. [img]smile.gif[/img]
        Lorax
