Blade Guard Alignment on 2424
  • Blade Guard Alignment on 2424
    Hi
    I just got my first table saw a 2424 and I cannot align the blade guard.
    Any tips. It is consitently off by 1/8". I have made the adjustments in the manual but with no success.
    Lisa
    It is hard to answer without knowing more about why the adjustments don't work.
    There are two adjustments; the first, which changes the angle of the spreader, is to make it parallel with the blade. The second, which moves the spreader side-to-side, lines the parallel spreader up with the blade. You can do this with a straight-edge (as I think the manual recommends) or by eye. If you use a straight-edge, the kickback pawls have to be held up out of the way.
      Rgads right, There are two adjustments and they need to be made more or less simultaneously.
      Jake
