SS16501 Variable speed Scroll Saw
  • SS16501 Variable speed Scroll Saw
    I am having some trouble getting my 02 & 03 blades to track straight on my Scroll saw. If I am running a board straight into the blade, at times I will have to push the piece of wood at an angle of up to 30 degrees to keep it cutting sraight. Any ideas how I can fix this problem?
    I can have that same problem on my much more expensive DeWalt 788. When I have the problem, it is the fault of the blades.
    If you very gently feel the sides of the teeth, and one side seems rougher than the other, it is the blade. Artifact of the way they are punched from blanks.
    Dave
