protective top coat on painted projects
  • protective top coat on painted projects
    Do you ever put any type of protective top coat on painted projects? I occasionally build a small project that is painted a solid color (white) and then my wife will paint some decorative trim or artwork on it to dress it up. I've wondered if I should put some type of protective coat on top of the finished project. Any suggestions?
    Alan
    My Shop
    Depending on the type of paint used, you may be able to apply a clear laquer paint to seal the artwork. I would check with your paint supplier to see if what you're using is compatable.
      I have used clear polyurethane over painted items I use in the shop & it works well on a work surface that I slide benchtop tools on & off of.
      Use safety devices or you may not need gloves.
