How To Post Images
See more
See less
frameless cabinets
  • frameless cabinets
    Is anyone building frameless cabinets or using the 32mm system for hardware instalation?
    Re: frameless cabinets
    I don't, I studied the system and like the conventional look my self,
      What's a 'frameless'? something without internal stricture near the corners? can you post pictures for the ignorant please?
        no face frame
          a lot of the knock down cabinets are the frame less, style, usually on 32MM layout, and it is a modular system
          two sites for some back ground, on the process and system,
          32mm Cabinetmaking
          32mm Cabinetmaking : Basics : 32mm System Basics
          32mm Cabinetmaking : Basics : True32 Ten Commandments
          http://festoolusa.com/media/pdf/32mm...Hole_Guide.PDF
          http://techdirections.com/32mmCabinet.pdf
          one of the keys to the system is a Line drilling machine, that can drill the holes in the panels, ( a multiple spindle drilling machine. usually a head that has right and left hand bits in it that will drill a side of a cabinet in one or two settings), SOUTHERN-TOOL.COM: New Page 1
          for the DIY shop some companies sell templates, that one can hand drill, J+R SYSTEM 3200
          and a banding machine is usually suggested, as well, as your using some type of 3/4" sheet goods that usually need the edge banded, and most all the faces and doors will need banding as well,
          much of the cabinets use some of the system if not all of the system,
          here is a how to guide on the system,
          http://www.cabsystems.com/KISSII/KIIrivDe-mail.pdf
          for pictures http://www.google.com/search?q=europ...w=1280&bih=823
          or
          http://www.google.com/search?hl=en&n...w=1280&bih=823
